Looks like someone changed the bezel probably for a later radio (most earlier trucks had the radio with two knobs coming thru the bezel) and probably put the screen over the original series of light sockets and you are getting weird readings because the 4wd indicator is now below the CEL/oil areas in the later screen.
The steering wheel and black trim coincide with a early first gen.
Use a screwdriver to press the locking tab in the notch in the headlight knob, slide out the ash tray. carefully pop the trim off along the base of the dash, take out the screws at the bottom of the bezel and across the top and see if you have two collumns of indicator lights in the message center or one. If you have one column you have the wrong bezel.
I haven't come across that cluster before, looks like the oil, temp and charging gauges are just huge idiot lights.
I think it was after the 2.8 before RBV's received CEL's.
