Why cant I buy......
Oh Caleb... I'm so sorry for getting your pantie knotted up like that. I promise I will NEVER have another opinion
You (again) have confused 'opinion' and blatantly wrong statements submitted as fact.
I never told anybody what oil to put in their motor. You (again) chose to jump on my case, for saying I don't use 5w oil. My reason my be wrong, but it still my choice. I never spread bogus info. I never told you to do what I do. I even said " if I'm wrong, I'll be wrong". But thanks, I always enjoy a good " back and forth" with you. Gets my blood pressure way the heck up. I appreciate how you flip my opinions into arguable facts and constantly tell me what an idiot I am.
I never run anything less than 10w oil, it gets way too thin for the summers here. As for brands, I don't really care too much.
"It gets way too thin for the summers here."
That is a statement of fact (based on a misunderstanding of how oil viscosities work). ADSM pointed you directly to an explanation why that was the case. I'm sorry that your blood pressure has gone 'way the heck up' over an inability to acknowledge a mistake.
This is the internet guys, everything on here is basically some random person you will likely never meet's opinion.
It isn't worth getting hot about, let it go.
25880
some diesel oils are rated for gasoline engines. and it's cheap at Walmart.
ok so I don't get what the bickering is about? I don't know what fastpaker is getting at? The dude says he wants to run 10w bc he wants to and you are jumping his shit for what reason now? He didn't go around telling everyone to use 10w-30. It's his truck so let him do what he wants whether he's right or wrong. I think people need to explain what the hell they are talking about sometimes bc none of us are in your head and can read your thoughts. Well, RonD might have that kind of power lol. I still don't see what the issue is here.....
I appreciate the concern for my bpr, but I was joking. Only my kids can get me to that point. Fastpakr I think your obsession with correcting me has gotten out of control. @91stranger :icon_thumby:
Short Answer: W stands for Winter[/SIZE]
“W” stands for “winter.” When oil grades are hyphenated (i.e. 10W-30), this indicates range of viscosity attainable with this particular oil, namely it behaves like 10 weight oil (less viscous) when it is cold or “winter” and thanks to viscosity modifiers (manufacturer added oil additives), it will behave like 30 weight oil (more viscous) when hot.
On the subject of oil weights and summer....
Is there really any benefit or downside to using heavier-weight oils in summer months and lighter-weight oils in winter? Some of my older friends swear it's essential to proper maintenance.
Oil is subjected to more misinformation, controversy, out-of-date knowledge, and myth than just about any other aspect of car maintenance. Using the right oil is an essential part of keeping your engine healthy, but what does that mean?
Let's tackle the specifics of your question first. It used to be that changing oil weight for summer or winter months was part of proper maintenance. Old conventional oil formulations had only one viscosity, and oil would thin out as it was heated. In winter months this caused starting trouble because the oil would turn to molasses and the pumps couldn't lube the engine properly. To combat this, a lightweight oil such as 10-weight was used for cold weather, so it would flow, while heavier 30- or 40-weight oils were best in summer months to prevent the oil from breaking down in the heat. This problem was solved with multiviscosity oil, oil that flows better when cold, then thickens and protects better when it's hotthe best of both worlds.
With an oil like a 10W40 (the W stands for winter), the oil flows similar to a 10-weight in freezing temperatures to minus 30 C and protects like a 40-weight at 100 C. With this innovation in oil performance, changing weights for the season is no longer necessary and may be detrimental. Modern oils are very effective across all temperature ranges, and new engines are designed and tested to work specifically with only the type of oil listed in your owner's manual. Older cars can use modern oils too, just base the first viscosity on your climate, e.g., 0W for northern Canada, 10W for Florida, and use the original oil spec for the operating weight. Most older cars work fine with 10W30.
There. Case closed.
Can we not bicker about this now?
I could have swore I read 10w for Florida and I do drive older cars.
:unsure:
Done.
for us old school guys. from a Chiltons manual.
older owners manuals had these charts in them.
I'll run out for more popcorn now.
25881
You can find several different charts online like this one. I can see why @Ranger850 doesn't want to use 5W in Florida. I personally just put whatever oil the manufacturer recommends, and call it a day.
@fastpakr once said of me...
"Facts have never really gotten in his way"
That was many years ago, i like to think im better now :)
(not a insult toward you fast, just sayin')
Motorcraft 10W30 in a gallon jug anywhere???
Its pretty easy to come by in quart size, but what gives? 10W30 PSD oil in everywhere in a gallon.
It also pisses me off its all synthetic blend instead of dead dino, but thats another day....
I was just at the Walmart near me had gallon jugs of motorcraft. When i went to buy my weekly quart for the 2.3
I use 0w20 in the winter... *gasp* :icon_rofl:
