- Jan 6, 2002
- Pittsburgh
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Total Lift
- 1.5"
- Tire Size
- 265/70-17
- My credo
- "220, 221, whatever it takes."
Winter tires all the way.
Changing from No seasons to Blizzaks on our Explorer Sport changed personality from being un-driveable to no longer needing 4x4, well almost. My 4x2 Ranger had 4 studded grips and I did better than most 4x4s with their all seasons.
Had I been aware of how much better winter tires made driving in ice and snow, I'd probably still own a Blazer.
If you're going to get one or the other then I'd say get snow tires. Been running Blizzaks on my wife's cars for ten years and her minivan goes as good in snow as my 4x4 and stops and turns better. Blizzaks are the shiznit but Firestone Winterforce are pretty good too and don't cost a lot. Or whatever generic snow tires your local tire shop has would still be better than all-seasons. Dedicated snow tires are also (usually) made with softer rubber so they grip better in the cold and on ice. Another upside is that your summer tires last longer.
Limited-slips are better, in a way, but if your tires suck then the whole rear end of the truck will want to slide out. With an open rear one wheel will spin but the other will help the vehicle track straight. With a l/s rear, both wheels will spin and break traction and it will want to slide around. You have power going to two wheels, which is better, but it takes a little different driving technique to master.
Hope this helps.
bummer i missed it.
