How much height difference?
RangerDanger1&
5+ Year Member
I have a 2003 Xl Ford Ranger longbed. I have 15’s on it at the moment. I’m trying to make it higher up so I’d like to put 31’s on it. Approximately how much of a height difference can I expect from doing this and is it a bad idea. Thank you for your help.
I don’t know much about tires or anything really. Is this a joke or being serious if it’s serious I’m not gonna bother with 31’s.
Your stock tires are 29 inches. 31's are 2 inches taller... The height of the truck would rasie by half of that.
1 inch...
How come my tires are 29 inches
I don’t know how to find that stuff. Could you explain it
Your tire size is listed on the sticker on your door jam.
friendly F. Y. I.,, the measured size will differ from the stated/calculated/advertised size. for example, if you go out and measure a 31 inch tire it won't be exactly 31 inches. different brands of the same size will also vary.
without using charts
example size of 235/75-15
that tire is 235 mm/9.25" wide at the sidewall (not the tread width).
75 is the aspect ratio, the tire height is 75% of the width, or 176.25mm tall, 6.94".
top + bottom, 6.94" +6.94", plus wheel size +15" equals 28.88" tall overall.
that's a whopping 2.12" difference, only 1/2 of which is on the bottom that raises the vehicle about 1.06"
going to that size will have a small effect on braking and acceleration, nothing critical, just noticeable.
