fastpakr
⭐Supporting Member
- Aug 6, 2007
- Roanoke, VA
- Tire Size
- 285/75-16
Okay, then you're reporting results from two different things.
The first thing you get is a list of self test results (KOEO). Those are then repeated, followed by a separator, then the continuous memory codes. It's important to pay attention to where the codes come up, because they can indicate problems in different ways or ones that occurred previously.
Is it safe to assume that you actually got 114, 116, then a separator, then 111? If so, the 114/116 are very likely meaningless and not going to recur when you run the test with the engine warmed up.
