93 ranger 350 2 speed with 3.08s
big block 302cid V6!
Buddy in HS had a 305 V6 in his GMC pickup.
chvlfrk said:
283 crank ain't goin in a 350 block without bearing sleeves.
There were special bearing shells specifically for this purpose: TRW MS3110P, but it was 35 years ago that I was doing this kind of thing; 283s were more common then.
Swapped in? Them only came in C60s and bigger didnt they?
Ill raise your 305 V6 though...id love to drop a 534 Ford in a dentside.
EDIT...
Wernt these bad boys basically 2 305 V6s molded togther?
https://youtu.be/vtfPFLQMbUM
Them big ol gas fired truck engines get me goin...
Swapped in?
Weren't these bad boys basically 2 305 V6s molded togther?
Nope, stock motor in early 60s GMC C10; I believe with 3 on tree behind it.
702 V12 is 2 - 351 V-6s molded together. There's one in a rod in Calgary area; he's been to a couple shows.
The >1k lbs of the 534 kept me away; and then there was the weight of transmission which would bolt up.
I always thought it would be cool to get 2 Aussie I-6 sohc heads and make a v-12 out of them.
Ok bobby, ill bite. I consider myself pretty knowing of what engines have/are out there, but WTF is a 302 mopar? A bored 4.7L?
EDIT
Actually, i think i remember hearing about those, similar to the chevy 302 in that it was born to meet SCCA(?) Cubic inch rules in the late 60s/early 70s ran in challengers? Very few were built though. Or am i totally wrong?
surprised.
well...its like a 304.633 or something so really a 305...but firmly in the 5.0 club.. super castings of head and block....fuggin killer setups.
essentially destroked 340.....as if a 340 wasnt ripping enough:icon_surprised:
at one time i was heavily into the 340's....had several run up/run down blocks. in 87, i built an offset 400 stroker...(closer to 410ish)
total fuking monster...
What little bit ive screwed with mopars theyve all been 360s and 440s. Seems like when i was about 10 my grandpa had a 71(?) Demon with a 340. I remember it was fast, or seemed to be to a kid.
Engine is built 425hp 400lb-ft torque at the fly wheel think im gonna have to upgrade the rear end the stock 8.8 i dont think will be able to handle that much power, any one know how much fab work it will take for a 9 inch to work?
