So, I started my transfer case rebuild.
I'll try to post pictures of the different stages as I go along.
1st. I'll have to remover the rear driveshaft flange to be able to split the case open.
I measured the nut size at 30mm, is that correct?
BTW, it doesn't look pretty... When I removed the transfer case, there was no input shaft seal left. I had a straight view on the bearing.
Stay tuned...
P.S. If a rebuild isn't going to be possible and I need to replace the transfer case, what options do I have for a direct bolt-on replacement?
I went so some junk yards and don't seem to be able to find another 1354. Thx.
Stay tuned...
