- Mar 26, 2008
- Age
- 33
- lewiston idaho
My advice to get it pushed through that last inch is just to push as hard as you can forward. Sometimes it helps to wiggle the back end around a little bit, the input shaft can be difficult to line up with the pilot bearing just right and you are pushing against the spring on the slave cylinder too. It is entirely possible to move the clutch disc off center of where it should be too and that makes it even harder.
There is some advice floating around regarding sucking the engine and trans together with bolts/allthread ... use this method with caution, if the input shaft is not in the pilot bearing or the bellhousing dowels aren't lined up, it's easy to break the bellhousing.
i always get the transmission in there and hook up the slave (so the fluid can move), put the transmission in gear and try to rotate the shaft so you know when its engaged, then wiggle the back end of the transmisssion all around, and try to push on the bell housing with your feet.
