Has any one ran lifted 63" Chevy springs?
RockRanger
Fresno CA
Has anyone tried using lifted Chevy Springs springs on there ranger? If so what brand and how did they work. A stock set won't give me enough lift. I am currently running the factory block, 6" ranger skyjacker springs and a longer shackle. The lift height is fine but the flex leaves a bit to be desired.
My BII has 3.5" lift Pro-Comp Chevy leafs under it.
I kept bending RBV-fitment leafs at the forward eye (both Explorer leafs and Skyjacker), so enough was enough. So far so good... I ditched the ridiculously-thick overload leaf off the Chevy packs for the nearly-flat Ranger OL leaf (long-side facing forward).
FWIW, the Pro-Comp leafs are closer to 7" longer from the centerpin to the forward eye than RBV leafs (most reports I found put (stock) Chevy leafs at 6" longer).
How well do they flex in comparison to the skyjacker ranger springs?
Sorry for the delay...
I was running RBV OL leaves on my Skyjacker packs also... I think that if you still have your SJ packs as they came (SJ OL leaf), you'll see a great improvement in flex with the RBV OL leafs in the Chevy packs.
I also noticed a lot less flex-steer with the Chevy springs too (due to their longer length).
