- Jul 17, 2014
- Central AR
I want my '97 to sit about 3/4" lower than stock. What would be the best way to do this? I'm not sure if I should do dream beams in the front or just do some lowering springs. As for the rear end, I've got the stock 7.5" rear end in it right now(probably only holding up because it doesn't have near enough tire on it). I have the 8.8(3.73, lim slip, disk brakes) out of the explorer I used for parts and I've got the leaf springs for it too. If I just put it on as it is, how much drop would I get? Should I put the Ranger springs on explorer axle? Some other combination(want it fairly cheap, but if it'll work better, so be it)
That might be confusing, I want my truck 3/4" lower. What's the best solution for achieving that while swapping to an axle that is already spring under.
