If for no other reason, you can bump start your truck with a manual if the battery is weak from cold or an altermator/starter failure.
Like an auto over a manual cause you don't have to burn the clutch? Get the right gearing.
A manual transmission is way better for most wheeling. Below is a list of things that a stock RBV manual tranny has over a stock RBV auto.
More reliable
Cheaper and easier to fix or replace
Allows you to bump start if your starting system fails on the trail
More power
Better engine braking
No overheating issues to worry about
Tranny always stays in the gear you choose
WOT hill climbs? Pick the right gear for the climb and stick with it. There's no reason to shift. Same for mud.
Booster cables guys, booster cables. lol, just teasin, ya, POINT to standards for that! (I try and carry a spare starter! hehe)If your battery or alternator dies you are walking anyway unless you have a magneto.
All valid and good points you listen Evan. But about hill climbs and mud. Momentum is key, and staying on the power is key. Do you start a long obstical in the same gear that you end up finishing in? Hasn't been my experience. Auto vr standard hill climbing I routinely see autos finish and manuals have trouble. Can't effectively hit a hill in a gear that gives you enough power to finish.
Yes, but the batt has to be so dead that the field is depleted in the alternator. This would almost never happen on the trail, unless you had a horrible hot to ground occur. It happens if something gets left on all night or the battery is left to sit for years.
There is almost always enough juice in the battery to maintain the alt field, even it it can't power a light bulb.
I have seen tons of starters die on the trail due to mud and water intake. Those with manuals bump start the rig and those with autos are SOL.
everyone is aware here the the power loss difference between a auto and manual is actually pretty signifigant
autos lose 25-30% power to the rear wheels
manuals only lose 15-20%
a 10% jump in power from a auto to a manual is a signifigant gain in the ass dyno category, ask anyone thats done a 5spd swap in a ranger....
My butt dyno has never given me numbers like that! lol.
I know manuals obviously have alot more satisfying throttle response due to the direct coupling of driveline, but once a torq converter is "locked up" they do quite well for themselves (from what I've learned). That is a big perk to a stick is the snappy throttle response.
Can you back this up with something? I'm interested to see.
I still stand over here on the lonely side with Sasquatch_Ryda.
