- Jul 23, 2010
- Age
- 63
- Pollock Pines Ca
"Guy's I did the fuel pump test"
Here is my results below I am using a VDO fuel pressure gauge oil filled. I am going to let it run more see if it starts popping
(Engine cold)
Key on 40psi
Engine at idle 32psi
Engine running at 2K 29psi
(Engine hot normal temp)
Key on 32psi
Engine idle 26psi
Engine at 2K 25psi
(Engine cold)
Key on 40psi
Key on 32psi
Engine idle 26psi
Engine at 2K 25psi
