- Jan 2, 2016
Right, well, it wasn't the computer, either. Replaced that, and the issue is unresolved.
Decided to investigate whether the problem is general, or localized. Pulled off the spark plug leads, from one cylinder at a time, back to front.
#4 off, engine wouldn't start
#3 off, engine wouldn't start
#2 off, engine started, and ran only slightly more rough than when connected.
#1 off, engine started, and ran only slightly more rough than when connected.
Deduced that the problem cylinders are #1 and #2.
After that, I ran a compression test, and #3 and #4 are in the 145lb - 150lb range. Meanwhile, #1 and #2 barely have any compression.
I was convinced, that I burned through the head gasket, between cylinders #1 and #2, so I connected a small (airbrush) compressor to the combustion chamber, TDC, valves closed. It held pressure, invalidating that idea.
Any thoughts?
Hi All,
I'm getting desperate, where my Ranger is concerned.
Went out, for a routine drive, three weeks ago. On the way up a hill (not a severe grade) I heard some detonation. Slowed down, to relieve the problem. As the drive went on, it kept getting (gradually) worse, and started running rough. Still, it did not light up the check engine light.
Took it home, and connected my Actron code reader.
No codes.
Guessed that the problem had to be fuel starvation.
Replaced the fuel pump.
No joy.
Replaced the fuel filter.
No joy.
Replaced the injectors.
No joy.
Took it to a local shop, where the owner connected it to his diagnostic equipment. He came up with a laundry list, for me, which I have started on.
Replaced the front coil pack.
No joy.
Swapped the original front, for the rear coil pack.
No joy.
Replaced the four passenger side spark plugs.
No joy.
Replaced the idle control valve.
No joy.
At that point, I realized that I was pissing in the wind, and came up with a new strategy. I'm asking the hive mind for help.
Do any of you have any wisdom, that you'd be willing to share, on the topic?
Thank you, so much, in advance,
Bernard.
1999 Ranger 2-door, 2WD, 5-speed, short bed, regular cab, no cruise control, 125,000 miles.
Bernard said:I was convinced, that I burned through the head gasket, between cylinders #1 and #2, so I connected a small (airbrush) compressor to the combustion chamber, TDC, valves closed. It held pressure, invalidating that idea.
I just thought a bit about this. If the head gasket is gone between #1 & #2, then pressurizing one will pressurize the other. If both of the plugs were removed, leakage between should make some noise. If only one were removed, you'd be able to build up pressure. Which was the case when testing?
An airbrush compressor does not produce a lot of pressure nor volume, to my knowledge, so it might not have enough capacity to cause noise, or build up enough pressure that is would be noticed if the leak seals enough when cold to blow past.
You know that the cam is intact, or #3 & 4 would not have their valves operating, so you are left with #1 & 2 valves, pistons, rings, and head being intact or not. I think.
You can try adding a Tbsp of oil to one cylinder at a time, and checking compression to see if it improves. Improvement would indicate leaky rings. No improve, and it likely valves or head gasquet.
tom
Did you find the fix?Hi All,
No codes.
No joy.
No joy.
No joy.
No joy.
No joy.
No joy.
No joy.
Bernard.
