- Feb 22, 2016
I have a 2003 3.0 V6 with zero compression on the third cylinder. All other cylinders were fine, around 150 psi. When I tested the compression on #3, it was absolutely zero. So I started taking it apart to pull the cylinder head. While I was unbolting the exhaust manifold on that side, I noticed that the head to the top exhaust bolt next to cylinder #3 was missing. The shaft of the bolt was still there, but no head, so effectively no bolt.
My question is, is that one missing bolt enough to possibly cause zero compression on that third cylinder? I haven't unbolted the cylinder head yet. Is it worth replacing that bolt and putting everything back together to test it, or is it more likely that there is a deeper issue actually causing zero compression?
I'm done working on it for the night. I need to get a couple of nuts tomorrow to pull that broken stud off. Thanks for any advice in the mean time to point me in the right direction.
