what is the door code, drivers side door under the axle section, the code will help up, i just found out this week i have 3.55 gears my code was 85, otherwise look on the front axle, there will be a tag with the gear ratio on that
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
