Will 3.0L run with Autolite copper core plugs?
Rangstang
Mesa, AZ
If it ain't broke, I can't fix it.
I replaced my plug wires and plugs with copper core Autolites to correct a miss, but now it hardly runs at all. I've double checked wire positioning, so I know that's not the problem. I don't know if it's due to a bad plug wire or if the 3.0 has to run double platinums. Does anyone know if they're a must?
as far as i know, theres no reason they wouldnt work. they will wear faster than the plats, but should still run just fine. i use autolite coppers in almost everything i buy plugs for.
any chance you knocked a vacuum line off or unplugged a sensor or something?
Hello . i'm new to the forum and i just purchased my ranger, but am a mechanic and when i started working on my ranger i replaced the plugs and wires, and the plugs that were in my ranger were Autolites. On Cyl #2 the Plug electrode was completely gone. like the plug was almost FLAT when i pulled it. I couldn't believe i didn't have an engine light or the engine was running rough. It just could be a coincidence, but i personally wouldn't put autolites back in after seeing that. I replaced my plugs with the Motorcraft Platinum plugs but have also always been a fan of the NGK's. Again just a personal opinion but i wish you the best of luck.
Did you check the gap on all 6 plugs to make sure they are correct?
Gap was verified on all 6 plugs to .044" as per the sticker on the core support.
Typically, the 3.0 prefers cheap copper plugs compared to fancy platinum/double platinum ones. Basic Autolites or Motorcrafts have a very good reputation among the 3.0 crowd. You shouldn't have any issues running a copper Autolite in the appropriate heat range. Something else is going on.
I only noticed one vacuum line even near me when I was changing them out. I disconnected it to get it out of the way so I wouldn't break it while working and reconnected once complete.
I've also seen two versions of wire positioning for the 3.0L V6 engines online. My Haynes manual shows this:
This is the other version I've found:
I recently put some in my 94 and it runs better t
Ford calls for single platinum or better. Motorcraft s432x single Pt are all you need
Can we like.. stop digging up decade old posts?
while we're here, it's double platinum for waste spark systems.
tip on one bank, ground on the other.
^^ this, double platinum. Motorcraft or Autolite is the preferred.
I run autolite iridium. 25 i think. Same plugs that the gm 604 crate motor in our crate late model dirt car runs. It seems to like them. Starts quicker than before.
