Escorts 2nd SAS
Ben, you can run a 2000 superduty pump, 100% bolt in, has extra pressure and flow, and a second return port, its about $60 from autozone, no mods needed...
SVT
SVT
Oh? It will bolt to the ranger bracket?
Sent from my SM-N910T using Tapatalk
I know i swapped my 91 f350 7.3 pump into my 96 ranger and vice versa. I also have a 3.0 pulley on it it was just a tiny bit bigger
Well, I guess I'm stopping at Advance Auto after work.
If you plan on locking the D30....you should plan on gathering parts for tons.lol
Sent from my XT907 using Crapatalk
SVT
What about on say a 99 5.0?
The Super Dooty pump is identical to the Ranger pump externally. Except it uses this resi for the HB return Escorts 2nd SAS
An F-SD (with hydroboost) should also have a touch higher flow
But has anyone actually proved this?
The issue with parts store pumps....is they don't always use correct internals. Chances are they just re label a Ranger pump and call it a SD pump because the average Joe won't notice or care.
Locking the 30 is just a thought. I plan on upgrading to tons in the future....so maybe I should just go that route. I get a lot of one back from taxes...hmmm
I'd put it towards tons.....trust me. Skip the upgraded 5 lug axle step....
That is a good point. I'll see what rockauto has.
I'll probably just go with SD axles
Talk to Brad about them.. He seems to have a lot of info on them since he is in the silly diesel scene where everyone is swapping to SD60s
If anything, an Aussie locker or one similar to it.
Upcoming TRS Events
Featured Ranger Based Vehicle
