- Aug 2, 2013
Okay it started yesterday morning when I got in my truck. I started it up and it immediately died. I start it again and it starts up just fine. I pull out in to traffic and accelerate at probably 3/4 throttle and get a bad sputtering. I played around to see when it does it and it was only at 3/4 to full throttle at rpm's over 2500. It would like sputter/cut out really bad to the point the rpms wouldn't go up. It doesn't do this at like half throttle though it will rev out to like 5k fine as long as you aren't stomping on it.
My immediate thought was a clogged fuel injector or something. Anyways I basically drove the piss out (well as much as I could without it sputtering) of and it actually went away. It drove fine the rest of the day. This morning I start it up and it starts up fine but I had the same sputtering problem. I forgot to even check if it was sputtering on the way home since I drive like a grandma usually.
Any thoughts on what this could be?
