- Aug 19, 2001
- So. Calif (SFV)
- 2.9 V6
- Tire Size
- 35x12.50R15
e
(shops who do this as a profession, competition crawlers)
You're asking the wrong crowd. Comp guys are usually loaded with $$$ compared to the average joe wheeler (and every tiny detail has to count for them), so of course they're gonna be all over ARBs, Detroits, Spools, etc.
Shops on the other hand I would think would be less biased against them (unless its the same shops those comp guys are using), but I couldn't say for sure, maybe they make more commission on full-carrier lockers.
Sasquatch is right though, many of these lockers ARE junk (perhaps these are giving the others a bad name?). ONLY the Powertrax units, and the Aussie Locker seem to be worth anything. Like Todd said, if you don't have a couple money trees growing in your backyard (as is often the case when you're not quite 17), these lockers are certainly worth considering. A limited slip is not gonna perform well if you get into any frame-twisting situations while offroad.
It should be noted however ANY of these lockers are only as strong as the stock carrier, so I wouldn't get too crazy on the tire size.
