- Apr 6, 2008
I've been wanting to put one of those instrument panels with a tach in my ranger since i bought it. So I finally went to the scrap yard this saturday and pulled a wood grain trim panel and instrument panel(with tach) from an 88 bronco II. The cluster appeared to be a plug and play, but when i plugged my harnesses into it nothin worked... So my question is, which clusters will work? My ranger is a 94 so maybe they did something diff in 1988. I cant imagine that the engineers would make you swap out wiring harnesses just for a tach..
Thanks
Thanks
I'd tried to do the same thing. I went to put my reverse glows from my 89 2.9 B2 into my 94 4.0 Ranger by swapping the entire assembly and nothing worked right at all.
