running with no diff
stegomon
auburn/minot maine
my driver side u joint and the middle u joint in my front end is gone...so i need to take the diff out....i reallly dont have the time to take it out then put it back in in the same day.....
so my question is can i drive a little wile with out axils and a diff in the good old ttb...
i dont see a problem...but you never know!!!!
mine has been out for a few years
your wheel bearings are no longer sealed without the axle shafts.
Stuff a rag in the hole and continue running the pinch bolt and you'll be fine.
Without the diff, what would the "pinch" bolt be pinching.
Well what I did is thread another nut with a washer onto the bolt, below the upper tab, so I could tighten the top nut down onto the lower nut and washer. It was essentially pinching the bolt itself if that makes sense...
Just leaving it out you will loose some structural support in that area and the beam could fail.
Sure they are. As long as you put the hub back on after you gut the axle. Do stuff a rag in the spindle tube to keep the crap out of your hub.
a rag wont keep water out. i like rick's idea, put stubs back in.
