sounds like you have a 4inch drop bracket/plate lift kit.I'm aware of both BDS and trailmaster that make a 4inch drop plate lift kit. Could be etheir brand.
the factory piviot bracket is aprx 7 1/8 from frame rail to the center of the axle piviot bolt hole.And your bracket is 11ish...
Since you blew some loot allready,the spacers junkie put up pic's of would be your best bet with out having to spend a anouter chunk.
do you know what kind of camber bushing you have? if you have the adjustable ones or the fixed, and if you have a fixed what size they are?
pic below is where to find the camber bushing
and this of the camber bushing still in the beam end
here a few "fixed bushings" as you can see they are diffrent sizes/offsets.
usually they will have what degree they are stamped in to the tops of them.
here is a pic of a adjustable one.its a 2 piece bushing,and you can twist them around to diffrent o's/offsets.
Just a word of advice for the future, make sure you keep a bumpstop on the driver side so the diff chunk dose not get a hole punched in it from the drop plate.or maybe replace it in the future with a drop bracket.
Do a search on the board here "drop plate" and Im sure more than enuff info will come up.
