Head help 1994 4.0
SmokinBbq
10+ Year Member
Leaking Coolant Head help 1994 4.0
I have 1994 Ranger 4.0 ,last week i noticed the heat not as good so looked at the water in the radiator and it was low i added water and heated up but then noticed water was leaking pretty good,,i took the ac loose and power steering and found the leak is coming from under the front of the head , I need help to figure out if it is the head gasket ,head cracked or whatever ,thanks people any help would would be appreciated , i miss my truch and need it . you can email me thanks
Welcome to TRS :)
Most common place for a leak in that area is from where the intake manifold bolts to the head.
My 4.0l had that leak.
Head gasket leak for coolant to the edge of the head is uncommon, and unless you are leaving out a major overheating event I doubt there is a crack
I would check the thermostat housing first i have the same problem at the moment
Welcome to TRS :)
Thanks , i had a overheating problem last year in the summer once ,but been doing good since then until now ,thanks for the message ,
I have the p/s and ac out of the way ,i see it plainly coming from under the head thanks for the message
It's an odd one.
Cooling system only has 18psi of pressure and only when hot, after head and block metal has expanded to full sealing for 600-1,000psi containment(cylinder pressure), which is why head gasket edge leak is uncommon.
I guess a warp or crack then, I would pressurize the cooling system to confirm location.
I had a pin hole leak in a hose that was spraying a fine stream at edge of rad, couldn't find the crack in rad but saw the obvious signs of a leak, so replaced rad............
still had the leak, lol, found the pin hole :)
a rotten hose will appear to leak from under the pass side head on the front of the block, just fyi.
