Looking to buy an 80's Ranger
mazd02
LBC
Hi,
I used to own a Mazda B2300 ( hence the username). Now my niece wants a 4X4 Ranger from the the late 80's to early 90's. Preferably 88-92.
I would like to know of common problems and what to look out for. Got around 5k to play with. Hoping to pay under 3k and use the rest for fees and upgrades.
Thanks on advance for the help.
You're talking about 20-25 yr old Ford for a girl. Unless she is a good mechanic, I would talk her into something more car-like and newer.
Take your hate elsewhere.
Of all the vehicles I or my family have ever owned my Ranger has been the most reliable. For the first 20 years it never needed anything except thermostats and a TFI.
My dad's Pontiac never shifted right, ever, and cracked both heads before it was 10 years old. His Chevy van had the security system die and strand us in Baltimore when it was 3 years old, then had transmission issues and running problems at 5 years, not to mention it was always wearing out the front end and the fuel gauge never worked right.
His F-150, in the 7 years that he owed it never once had a year where the 4x4 didn't have to be serviced, usually a faulty CAD unit. His 06 Explorer has been through two wheel bearings and a radiator.
Mom's Volvo was never right from day one. It was an 01 that we bought in 03, and it was always broken down, making noises, vibrating, eventually costing more in repairs each month than in payments.
The Mariner hasn't been too bad, the AC compressor grenaded a month after she bought it, and it needed plugs and valve cover gaskets at 100K, but it makes a noise that nobody can find.
My sister had a Volvo 850 that I could never keep running right, it chewed up plugs and MAFs and I never could figure out why. Her VW has never been quite right either, oil leaks, blown out CV joints, starting problems, running problems.
So far the wife's Escape which we bought new has been the only thing to be less trouble than my Ranger. I had to replace a rear shock at 22K miles.
In the first 150K miles all my truck took, aside from the normal wear items, was a few thermostats and a single TFI.
Of all those vehicles only the Chevy van and the Escape were bought new. All the rest were 2 to 5 years old when purchased, except my truck, which was only a year old.
The older stuff is better, there's less stuff to break, and they are much more simple to work on. I had an 88 F-150 that sat in the middle of the field for 6 years and was able to fire right up, if it hadn't been for everything rusting out I would have kept it. With that said, your main enemy is rust, make sure to look around the vehicle to make sure it's structurally sound, other than that I don't know about finding a low mileage one, but there are many out there that I'm sure will meet expectations.
Doesn't matter what you buy its going to have some sort of problems at some point whether it be at the beginning or later on after purchase.
As far as serious problems there really aren't any to pinpoint right off the top of my head. It all really depends on how well it was taken care of by the previous owner(s). Get one that's neglected and it may not even make it out of the place it's parked for a test drive. Get one that's been well cared for and you may not need to do anything to it other than routine maintenance. Then again it could die the next day while the neglected truck keeps chugging along (My Bronco 2 is like the latter).
Bought a brand new 2006 Chevy Cobalt and it was junk right off the lot, dealer refused to actually check into the transmission issues like not shifting into 1st or reverse unless I shut the car off first. Then later on a couple months into ownership I noticed a slight grind when going into 3rd gear from 2nd. Dealer claimed nothing was wrong. 15,000 miles it got a transmission rebuild. All these problems in the first year then went and traded that POS in on a 2008 Toyota Tundra, and now almost 6 years later and 70,000 miles I've had absolutely no issues.
I've had several older vehicles and I can say that most of them were a lot more reliable than that new Chevy Cobalt. Hell my 96 Jeep Grand Cherokee had 200k+ miles on it at the time and it was more reliable than a car that wasn't even a year old then. Don't think buying a new car is going to be trouble free either. The older vehicles are usually much easier to diagnose and work on. Far less complicated computer stuff in them to keep you scratching your head.
2.9's are known to crack heads.
Ticking lifters are kinda almost fairly common on both 2.9's and 4.0's.
A4LD's are not a really durable trans, if you can (and she is ok with it) the M5OD is a much better trans but is a manual.
The 4.0 comes with the stronger 8.8 rear axle (28 spline) and D35 front axle. Depending on what you are doing the D28/7.8 is perfectly fine for a dd type rig if you have a little sense (I put nothing but brakes on mine)
Really it is a crapshoot, this far from the factory it is hard to tell what they have been through.
+1 on the older vehicle!
The newer stuff is all plastic, made by the lowest bidder for the contract, then all assembled togther. I have a 2011 F150 screw 4x4. good running truck..very cheap build quality of materals. The metal they use for the hood,doors..etc..is so thin you can see the hood flex as you drive it. When you shut the door you can watch it flop back and forth. Interior is all plastic and it reminds me of the "snap-tight" model kits as a kid.
You can get a nice ranger in my area for 3K. Look around and do some shopping...there was millions of rangers built. So the odds of finding one you like is good.
Thanks. Great info.
They must have really cheapened them up, the aluminum hoods on my '02 F-150 and my dad's '05 F-150 may as well be made of cast iron going down the road. You may need to adjust the little rubber hood bumpers that support the hood when it is closed.
Not flexing as in the whole hood moving. I mean flexing up and down due to wind or pressure applied to it by the wind. it is as if someone was pushing on the center of the hood with their hand making it pop up and down.
or like pushing on a empty aluminum pop can with your thumb.
really thin materal for all the panel skins.
Make that a +2. Old is gold, as my very very cheap colleague has said. (He's so frugal, he kept charging his 8+ year old car battery rather than buying a new one.) But yes, even my dad's company E-250 feels like it is built out of soda cans. I don't think I would ever buy something new like that, even if I could afford it.
Only thing I would be concerned about with getting something too old is difficulty in sourcing cheap parts. I remember reading about how at one member's local yard anything older than 95 is hard to find. At one of mine a majority of rangers were third gen, but there were a few that were older and even less that were newer. I guess it depends on where you go.
I used to be afraid of the 2.9/a4ld combo years ago....
Then when I was away at college and roaming a junkyard I came across a 1989 Bronco II Eddie Bauer sitting there near the rebuildable wrecks and the crusher. Stopped in the office and found out that the BII was slated to be crushed. Took another look at it, asked how much, played with it a little with the help of one of the guys in the yard and plunked down $250 for it. I lucked out, they got it in and the poor thing was headed straight for the crusher so they never transferred the title, I was able to get a clean title for it by going back to the former owner.
It needed some help, previous owner smacked a deer with the passenger front. Took out the grill and headlight, smashed the fender up, caved in the passenger door and bent the front bumper. It also caused the truck to stop running because (as I discovered) the fuel pump had been replaced on the sender and someone used crimp-on splices to connect it - they were laying in the bottom of the tank. First order of business after getting it running was to throw a full tune-up at it. Plugs, wires, cap, rotor, fuel filter, air filter, oil and filter, trans oil and filter, etc. The stuff that came off/out of it was so nasty I'm shocked that it ran at all. When I got done I fired it up and it sat coughing and sputtering for literally over 5 minutes. I thought I killed the poor thing. After that she started smoothing out and I have to say it was one of the best running trucks I've had experience with. After doing some research I calculated that it had somewhere between 180 and 250k miles on it (someone had changed the gauge cluster at some point and Carfax didn't have a lot of mileage numbers for it). I ran it for two years at college and sold it before I came home. Kind of wish I would have kept it.
Finding the older stuff in a junk yard is hard to do anymore. From my understanding a few years ago the EPA started cracking down on JY's wanting the older stuff gone...bad for the planet..needs to get recycled.
Then we had "cash for clunkers" not to long ago, that took many very good vehicles off the road. Had crap poured into the engines to make them worthless...then sent to the crushers.
So now it makes it harder for anyone that has a older vehicle, to keep running and on the road.....using used parts that is. Company's like LMC truck has almost any part you need to keep a ranger alive. a person could almost build a complete truck from the catalog.
I dont hate my Ford, until I start working on it. :D
And buying a 25 yr old anything is bound to need more upkeep. So the niece is going to have to pay to have it maintained, fix it herself, or have her dear uncle fix it .
88 ext cab with minimal rust.
4.8l gm powertrain swap, hp d30 swap, explorer 8.8 disc swap.
easy to find parts for reliable fun to own truck.
i could do that for 5 k if i could find a decent truck to start with under 1200.
