b2 lift
haha i think ill buy my self one first... all the local brewers around here ether have an early bronco or a full size for advertisement other than the one that uses a scout!
What kind of alternator would be good to put in I'm shopping around particularly on James duff any suggestions?
Sent from my T-Mobile myTouch Q using Tapatalk 2
so im about to order some eb coils do i need to order the plates and what not im just not sure of what to order for the eb coils
the upper coil buckets on the B2 will work, not a perfect fit...but they'll work. You can use a u-bolt or short piece of chain as a retainer if you want.
on the bottom, for the coil bucket, I custom made mine... the stock B2's will NOT work for the EB Coils. You'll have to do something for the bottom bucket. I made mine out of some 1/4" metal cut round the size of the coil... and a thinner piece shaped to fit the bottom of the coil and then another 1/4" piece (smaller circle) on top of the bottom coil of the spring. Understand? :icon_rofl::icon_confused::icon_confused:
some what could i just use the bottom eb retainer plates?
Yeah I'm sure you could.. I made my own to save some $$$
You can kinda see mine here
b2 lift
b2 lift
b2 lift
then this is what happens when you try to use coils to long for your drop brackets...
b2 lift
b2 lift
that helps alot im more visual learner than anything and the coils haha i died how long were your brackets
Those were 4" brackets with coils that have me 7" of lift.
