- Aug 6, 2007
- Age
- 40
- Western Mass
i literally have to repack my wheel bearings and spindle bearings after every wheeling trip, water gets in every single time, and fucks up the grease bad.. im beginning to think im doing something wrong, or i am missing some sort of seal.
brand new this year: (2) skf spindle bearings, (2) spindle seals, (4) timken wheel bearings, (2) wheel bearing seals.. i silicone the hubs to the rotors, because one of the o-ring seals got f'ed.. the water is either coming in through the spindle seal or the wheel bearing seal, but the inner bearing is always worse-- so i assume its mostly coming through the wheel bearing seal.
two of my bearings are TOAST.. i repacked them less than a month ago and they were still mint, i went through some deep water last week wheelin, drove the truck once since then, took it apart today, and some of the roller bearings are worn/beveled noticeably, and the cage is very loose, oh and as always the bearings barely spun by hand they were so caked with black crappy grease water dirt oil mud mix.
in this pic:
i do NOT have: #36, 37, 38, 51 <- truck didn't have them the first time i took it apart. described in this: http://www.therangerstation.com/tech_library/pdf_documents/Dana_Ford_35.pdf
as:
36 — (2) Slinger
37 — (2) Oil Seal
38 — (2) Spacer – Wheel Bearing Spindle
51 — (2) Brake Dust Shield (i have the big splash shields though)
i didnt know they existed until looking through these exploded views today. are those used on all trucks?
also my spindles do not seem worn where the inner wheel bearing seal rides on it.
in this pic:
as:
36 — (2) Slinger
37 — (2) Oil Seal
.but at least you don't need to buy seals to regrease the spindle bearing.my wheel bearings have fared alright but that damn spindle bearing has cost me a few stub shafts.almost reason in itself to do a d44 knuckle swap .
