did some searching, didn't find what i need. have a 95 ranger 5.0 and SAS need to know what you guy use for a front shaft with a 98 f150 elec t-case?
thanks, Erik
			thanks, Erik
Whatever shaft you can find that has the ujoint sizes on both ends should do.
Remember, it's cheaper to shorten one then extend one.
Sent from my rooted SPH-D710 using Tapatalk 2
Grab a stock front shaft from a ranger, and use the dc off it, much cheaper...
SVT
No, find a ranger front shaft, take the double cardian joint from that shaft and install the 4406 Tcase side flange onto the double cardian, saving you the $$ from buying a double cardian...
SVT
Starting in 97 all f150 and expeditions used the ifs differential that is stationary, so the double cardian joint is no longer needed as there is no travel like previous years. Superduties however, do have a traveling front axle, and those would be your best bet...
SVT
