- Feb 4, 2008
- Southeast USA
Doing my camshaft syncro and sensor.
Setting TDC so that the zero mark on the harmonic balancer (fifth tooth to left of gap) is centered on the crankshaft position sensor (between edges of flat spot). Then looking at trigger finger it should be centered in the gap of the syncro.
However, it was not. The finger was just off left of the gap. I had to move the TDC CW some more so that the finger was centered in gap - that's the only way the alignment tool will fit. That put the zero mark at the 12 o'clock position of crankshaft rotation. But there seems no corresponding engine mark there.
Question then is where the hell is the TDC mark on engine? The zero mark tops out at the top of the crankshaft rotation when the syncro finger is centered. All I can see is what looks like a corresponding TDC mark behind the crankshaft position sensor on the front cover.
Syncro is factory original and has never been moved.
Thanks for any clarification.
