This thread is great.
Ive got a good one that still scares me because this guy is still in business. about 3 years ago one of my Rangers dash brake light would not illuminate. I checked everything related to the brakes/parking brake. I came back with nothing and figured it has to be an electrical issue somewhere. I had two other Ranger projects id taken time from and much rather finish so I called up a known guy in town that deals with electrical/audio on top of being a service station. I explained to him my dash light for the brakes wont illuminate at all. I explained the ABS does illuminate and works in the startup check cycle, and if a fault in the system is detected but the brake light wont at all.
I explained I even removed all the fluid from the system as a fault test and got nothing from the brake light but the ABS did illuminate. This is when he tells me oh know the ABS and brake light are totally different. If there is no fluid in the system only the brake light will illuminate
I took a moment and said the entire system runs off pressure (duh) if there is no pressure in the system the ABS cant work properly either. Without hesitation he replys oh no they are two different things. That ABS light wouldnt come on in that situation, you have another issue. I said ok, yeah well ill just have to figure this one out myself. He said oh no I can fit you in Monday. I said no, I dont have the money right now ill set up an appointment when I do.
Yeah right. How can you be in business not having a clue of how something as simple as the brakes and ABS is tied together.
Oh I guess the point is a person ask me to do this and I declined.
