- Mar 26, 2013
- Amarillo Texas
The truck does fine wile under 50 MPH then starts to shake and rattle a lot till about 60-65 MPH. Any help on why and how to fix this? Thanks.
Just the usual, tire balance, alignment, tie rods, driveshaft.
Dave
+2 ^
Check for leftover mud on the insides of your rims, followed by tire balance and quick balljoint check (rock the tires back/forth), then grab ahold of your driveshaft and see if it shakes... If it does, that's bad. Also try the tierods if it's not one of the others. I'd bet on tire balance though
^x3
Also check out your driveshaft like mentioned and if it moves after you move it up and down or side to side change out your u-joints and use quality u joints!
x100+infinity, Bro. Take it to a shop ASAP. Could get......Dangerous !!!
How bout you check those wheel bearings out too? Are you trying to reuse a ujoint?
Make sure the holes in the yoke arent all messed up. I wasted a whole axleshaft and brand new joints that way.
