More success!!! I had it running for a good 10 minutes today. It even moved by itself. Didn't go far, just out of the garage and right back in because it was starting to storm, and I found this right after I pulled it out.
About 4 feet below that is the top of my garage door.
Makes the one I took out of Brinker's white truck the other weekend look dinky.
Congrats! I knew if I could get it to work you would make it look easy. (And professional)
Well at the moment it looks neither. I still have no washer bottle, and the air cleaner box (I have it all screwed together with the filter in it and everything) is clocked so that it is pointing up at about 11:00 if you look at the front of the truck. Wires everywhere that have been ripped out of their bundles, unhooked connectors with single clipped wires all over the place.
It actually looks more like someone with no clue is trying to take it out blind-folded only using a set of bolt cutters.
Does it seem like you got the cluster all figured out.
Out of Curiosity, are you using the donor wiring harness onto your ranger?
I think I have the important parts of the cluster worked out. Some of it I am not sure of yet. The CEL works (I'm sure because it is on), the tach was running at about 500 at idle, so it works but isn't reading quite right since I'm sure it is running higher than 500, the back-lighting was working in the kitchen, but doesn't seem to work right in the truck, probably just an unhooked ground. The oil light is lit up with the engine running, but that is actually a good thing because the 89+ sensors work backwards of the older ones, so a gen-1 cluster hooked to a gen2+ oil pressure sensor lights up the light when it gets pressure (so I have pressure). Turn-signal tell tales work, but I am concerned because they flash at the right speed, but the front bulbs aren't even hooked up I don't know about the 4x4 lights yet because the dash-side plug is still on the couch. I don't think the gas gauge is working right, but I'm not sure because I don't remember how much gas is in it. I also haven't gotten it warmed up enough to see if the temp gauge is working right.
I ended up using a hodge-podge wiring set up. All my dash and engine wiring were taken out of an 88 two years ago after I had some big wiring problems. For the dash I sat down with the 88 and an 89 dash harness next to each other and the two wiring books, and just started moving the connectors. If the pins crimped to the wires were the same I just unpinned them one by one, figured out where they were supposed to go on the opposite side, and plugged them in. If they didn't fit I cut the wires and spliced. Once I was relatively sure I had it all close enough I just plugged it in and started testing things. I had a dash harness, battery, and some cables in the house that I used to power it up. That of course was after about 3 hours spend with a multimeter, and test leads tracing out the printed circuit and figuring out exactly which pins did what.
Then I acquired two 3rd gen Ranger engine harnesses and a 94 Explorer harness, again sat down with the books, and started re-pinning. It is fairly common knowledge that the Explorer harness is pinned differently than the Ranger harness, but at the end of the day they both run the same lights, same accessories, and same engine, so I figured that with the right parts and diagrams it can be made to be the same thing. Most of the wires go in the same spots, but some are a little different, most notably the wires for the rear lights in the Explorer don't pass through the engine bay, or the bulkhead connector. They stay inside the body the whole time, so I had to add those wires out of the one Ranger harness. The biggest thing that made this a little difficult is that I pretty much had to have two Ranger harnesses, one to take the big connector off of, and one to look at, because the plugs are not the same. The unused pins in each one are blocked off. To add to all that I have some plugs from the original 88 harness spliced into the Explorer harness to connect the rear of the vehicle to the powers/controls.
So basically I have an 89 Ranger dash harness, going into a 94 Explorer harness, to run a 92 4.0L, and it is all dressed up as an 87 Ranger.
Did that answer the question?
Also, I have to odd tick with it running, but I'm not sure what it is. I'm not even sure it is something to worry about. If all else was correct I might think it was lifter tick, but it isn't missing at all, so I have to think I am getting full valve lift. Also, I don't have any exhaust hooked up after the Y-pipe, so yeah, it's loud and hard to hear anything really well. For all I can tell it might just be really loud injectors. It might also be in the exhaust, and something that I can only hear because the cats and mufflers aren't hooked up yet. It's just so dang loud from the open exhaust that it is hard to tell.
So basically,
