- Mar 13, 2011
I did some searching but didn't find anything really conclusive. Swapping rear ends is new to me, so I want to make sure I don't drop cash on a rear end that requires major modifications to work. The main goal is swapping to a 4.10 ratio.
I currently have a 1994 B3000 with 7.5 rear, 9" drum brakes, 3.73 ratio and a limited slip (Axle code F6).
I have found a rear off a 2004 Ranger that is roughly what I want - a 4.10 ratio. It's an 8.8, but from what I understand I would only need the larger U-bolts.
Beyond that, will everything else just bolt up?
I think the brakes on this rear had ABS, which my truck doesn't have. Would this be a major problem?
Edit: Just found out it has 10" brakes. It is the complete rear axle. Do I need to replace the master cylinder?
