- Mar 13, 2011
- Automatic
Also they left you the brake lines from the splitter on top of the axle so you dont have to do anything to modify the lines. Just screw in the flex hose from the splitter to your fitting on the frame rail and you are good to go after bleeding the rears.
Awesome, so then all I'll need to do is hook up the parking brake cables and bolt it up. Thanks for the tip!
