- Aug 26, 2008
- My credo
- Failing is easy. Everyone can do it.
It's about that time to get the front end worked out and get the rear end (of the truck) also worked out.
I found the install height of the springs to be 10.5 inches for the coils. This way I'll know if it makes sense to replace the springs/if they need replacement..or if my alignment is totally hosed for camber.
Now in reference to the rear springs. A normal spring looks like it has a mild 'arc' to it. My springs look like they have a reverse 'arc' effect going on where the axle mounts.
We have a local firm that does nothing but spring work. The manager stated they could 're-arc' the springs for $45 a pop, if I carry them in.
I'm wondering if it would make more sense just to replace them all together-- I can get a used set for about $55ish per side. Or would I be better served by installing "Explorer" springs as per the tech part of the site? I'm not looking for a suspension lift per-say at this time. More or less to get the truck back to normal. If the explorer spring would be a better solution? What is the axle code so I can look them up online?
Thanks!
S-
Thanks!
S-
