- Oct 9, 2008
- Age
- 48
- Columbus, GA
I did not notice they had demensions. Thanks.
What is this SAAB switch you speak of? And at what temp does it activate each speed? Have a pic of the mount job you did?
Sent from the can
I have a Flex a lite 118 or 119 (one is a pusher the other is a puller, I have the pusher) with my V8 swap. It did a fairly decent job of keeping it cool. It struggled when the truck wasn't moving so I added a pulley driven low profile flex fan with an Explorer shroud to the mix when I changed to the 5.0 Explorer FEAD, hardly hear a peep out of the e-fan anymore.
That is on a truck with a HD 4.0 Explorer radiator (which IMO is JUST big enough) and a 5.0 V8. Pushers do not work as good as a puller either, I think mine is rated 2500CFM.
The Taurus fan takes up a lot of real estate in a tight engine bay which is what nixed it from my build. BTW O'Reilly's had the dimensions of different OEM fans on their website if you need to go trolling for an oddball size.
Chances would be nill they would stock a fan let alone a motor, just the motor vs a whole fan would depend how much a new assembly cost.
What is this electric fan mod do? Like, what is it exactly, I know there's a fan that can be controlled by a remote or such and that's about it.
I get a kick out of Bobby. Hey man, all anyone was doing was steering him away from the cheap POS chinese Ebay units. Taurus, Contour, Cougar XR7, Volvo, any will foot the bill. If you go back and read, you will find that there are other suggestions made as well.
FWIW, this is my fan on high.
i read every post.
the volvo fan is definitely a nice unit, i played around with many of them, hyundai fans work real good and are compact as well.
dont get me wrong, the taurus type is a great way to go, it will keep the ac cool for damn sure.
Years ago I had the Flex-a-Lite Black Magic fan, and it sucked horribly. Absolute biggest POS I've ever bought for it. I wanted to use a factory piece. Almost used the Contour fan, but it was going to be an ordeal to pull it, and I wasn't in the mood. The Taurus fan takes about 2 minutes to pull.
I actually looked pretty close at the Volvo fans I pulled my my controllers from. They look pretty dang similar to the Taurus fan. I think about any OEM fan will work fine for an RBV motor unless you wheel. Then I would get something like the Taurus fan.
If this works out good, I am going to some up with something for my F150. I'd love to get a more MPG's out of that thing.
