Escorts 2nd SAS
I've been thinking about cutting our the center of mine.
Sent from my rooted SPH-D710 using Tapatalk 2
I have a dumb question....Everyone I talk to about putting a D30 in my B2 they tell me its a bad idea. I had a D30 out of a 97 XJ practically given to me and want to use it and not a fan of TTB. What are some of the pros and cons of this swap?
sas is simple. ttb requires knowledge.
there's nothing wrong with SENSIBLE wheeling on a d30.
go for it. :icon_thumby:
The Dana 30 is a strong axle for daily driving, weekend wheeling. The axle does have some weak and strong points.
The axle tubes are thin and can bend. A simple truss will fix that. Another weak spot is the inner c's will bend and create camber, gussets will prevent that.
I have wheeled my d30 for 4 years and only problems I've had is one bad axle joint and on the 3rd wheel bearing hub.
Sent from my HTC ONE using Tapatalk!
Didn't get to swap the pump or box. Yesterday I helped my brother on his Yota. And today I had to replace a bad wheel bearing hub. It was so bad that it could of fallen apart any minute. I had to spend the money I didn't have to get a good one, a Moog this time with a 3yr warranty.
Here is what I was saying by gusset the inner C
those things are a bitch to install. They look all easy and everything there, but thats because the axle is removed and all torn down.
you can also get these, much easier to install.....$39 + shipping
J11743
i did the same thing on my turdy except i made them from 3/16" plate i already had
J11743
These look like ones from Iron Rock.
A truss and gussets I should or done to mine. But now its to late for this axle. It's already bent from my heavy truck.
