- Apr 28, 2013
New to TRS, but I figured i'd join the site since i'm about to start heading up a Ranger V8 swap. And there seems to be a ton of good information here so thanks.
Finally going to get the ball rolling on this project. I have a 94 Extended cab 4.0 auto I recieved in the death of a family member. I decided to keep it for hauling stuff around, as a general beater for the most part. I have a pretty serious 427" 93 Mustang that I drag race, I built it from the ground up, cage, motor plates, powerglide etc etc. I do some welding when needed, I can do exhaust and headers etc. Mainly looking to turn this truck into a fun street cruiser on a BUDGET, very little track duty though. And off road is not my thing..lol
All in all i'm figuring about $2000 to $2500 complete ready to run, and that includes small drag radials, rear end rebuild, carb to pan swap.
(This does not include parts I have laying on the shelf, if I was starting from scratch it would be different)
Right now the build is going be a bit different from what i'm used to..LOL
Flat Top 347 should be about 10.5 or 11:1. ( I have this retired SB out of my Mustang, will pull a few mains and check bearings before assembly)
E85 fuel
Cleaned up GT40P irons with springs
Stock HO cam w/ 1.7RR, retarded 4 deg to help broaden the powerband
Cleaned up Weiand xcellerator single plane
650 E85 carb
Full 2.5" exhaust with mufflers
Electric Fan
Full explorer accessories, AC PS etc.
Today I ordered a box load of stuff to get going.
Electric FAL fan
Oil filter relocation mounts
Swap mounts
Headman headers, may need to modify for use with Gt40P heads
TFS Spring kit for GT40 heads
1.7 Crane Rockers
Cheap B&M flexplate to use with the AOD and 28oz balance
Most of the gaskets, timing cover, valve covers, oil pan, intake and exhaust.
Cheap summit valve covers
Trans is a stock rebuilt AOD I bought for $200
I plan to get it running and test, then I will probably do a Lentech Street Valve body.
Rebuilt stock track-loc with 3.73 gears, I also have 4.10's and the stock 3.08's I think in it.
Thinking about some small drag radials on the stock Ranger wheels just for a little extra traction later on.
Also contemplating installing a cheap plate system with 50-75 horse jetting for any track fun I may have.
I also have a set of Jegs Pro-stars 15x8 rears and 15x4 fronts I thought about sticking on it...we'll see if i wanna go that far.
I think it will be a fun little street bruiser, it will be 90% street, and maybe a few local bracket races in there if it runs how I hope.
I've played around with cams on EA pro, the stocker should get up to about 5000 before it starts to peter off. But low end tq from idle all the way seems pretty strong.
I'd like to see 300hp+ and 330+ torque to the wheels through an AOD...low rpm is fine for this.
If it ran a 12 second anything i'd be tickled pink.
E85 fuel
650 E85 carb
Electric Fan
Electric FAL fan
Swap mounts
1.7 Crane Rockers
