- Sep 14, 2007
Question:
In your experience (reading online or in real life), if I locked this axle, how likely would it be that I would twist an axle?
I don't think running a locker while pulling trailers really counts as testimony. What I need to know is if only one wheel is touching the ground, can the axle diameter withstand the torque?
If not, is there anyway I can put 31 spline axles in? What is the approx cost?
Or should I replace the whole axle with an 8.8 with the 31 splines? What's the cost of that?
A story:
My friend has a jeep with a d35 in back. The spider gears explode. So he parks that and drives his ranger with the 7.5. Not long after, the cross pin falls out and gets ground to bits by the ring gear. Here he is with 2 vehicles with bad diffs in the same month.
So I put a new 3/4 inch shaft in for the cross pin for him, but the ring and pinion are damaged and it makes a noise on the coast side. On the jeep, the cross pin holes are wallowed-out, so I drill the .685 hole to .75 and use the 3/4 pin. I weld everything solid. 3 days later, he twists an axle in half just driving normally around town. Never even took it wheeling.
So I'm reading online and discover the d35 is a major piece of junk. See here http://www.billhughes.com/dana35c/
I find the d35 has axles of 1.16" diameter. The 7.5 has axles of 1.2" diameter. So now I'm worried that the extra .04" isn't enough.
Honestly, I think the 7.5 inch ring gear is fine. The 3/4 cross pin is fine too. My only concern is the 28 spline axles.
Btw, all vehicles mentioned here have 31 inch tires.
Thanks
A story:
Thanks
