- Jan 1, 2008
- east coast
First of all . . wow, do we have some inaccurate info being slayed around as gospel. A properly designed cooling system will overcool an engine if allowed. If it cannot do that, then it is not properly sized. Fact, forget everything else, this is gospel.
Second, as junkie said, the thermostat will then control the operating temperature of the engine by controlling the temperature of the coolant. Typically the operating temperature will be about 7 degrees over the rating of the thermostat.
Adding a 4.0 radiator is a decent choice, however a proper operating 2.9 radiator should keep a proper operating 2.9 engine cool. So you decide where the problem is. The 4.0 radiator will certainly do the job and WILL NOT cause any temperature problems with the 2.9. I happen to be using a 4.0 radiator with my V8 swap and it does just fine.
