Escorts 2nd SAS
Yes it was, and from the pics I saw on Facebook, looks like we left to early.
Sent from my HTC VLE_U using Tapatalk 2
It was fun until 530 lol. We ran Mild to Wild with run of the Bundy Staff guys. It was 1.5 miles long. His guy blew a rear diff early in the run so we just went ourselves. The first mile was a blast. Then we got to the last section at 530pm. It was a muddy disaster lol. I ended up overheating on the way back to the parking lot. My upper radiator hose blew off and it sounded like a bomb lol
So any major parts destroyed/carnage?
Sent from my rooted SPH-D710 using Tapatalk 2
I just did a quick check on the truck. I might have a problem somewhere with the antifreeze. I am about a half gallon low and the overflow was empty. The whole day I kept wondering why it was puking more steam from the exhaust than others. I will have to look into this soon. I also noticed it smelling like it had a leak.
The steering pump was empty when I got back to Fort Wayne, the box blew out another seal. I NEED to get the other steering box on there ASAP.
I apparently didn't trim enough of the fenders, cause the tires still rub at full stuff.
If she is eating anti freeze that's not good.
I sure hope not, I was beating on it pretty hard on some of those muddy hill climbs.
I blew an axle shaft and cant get my engine to turn over. I might have finally killed my 2.9
BTW, it was a great time. Thanks for getting that all setup Ben. Work out great and it was nice to meet you.
It was a good time. Maybe it can happen again this year.
It was just the upper radiator hose that was leaking, the clamp was broken. Hasn't leaked any since I replaced the clamp. That's good at least.
Found out the problem with it running like crap and getting crap MPG.
The pass side O2 sensor was loose. Loose enough to remove by hand.
And next time you go to take it out, it won't be so easy.
Haven't updated in a month. Was planning on changing the steering box last weekend cause it is leaking like crazy. And was going to change the pump at the same time. Well, I hurt my back at work and can barely move around. Been bothering me for two weeks now and sucks cause I want to get stuff done since it is nice outside. So hopefully I can get back to normal soon!
hope ya get to feeling better buddy!
Event Coverage
TRS Merch
