- Oct 4, 2012
- Alpine, Ca
You want some cold air? Drill some holes in the front of your air box. A K&N isn't going to do squat. Save your money.
Dyno sheets or GTFO.
I'm sorry, any "slight difference" and the "engine runs freer" is probably just psychosomatic.
What is restrictive about the factory tubing........
Nothing.
CAI kits are a huge waste of money on rangers. And many other vehicles.
Just get a better filter.
The 93-97 (at least my 94 does) have a cold air intake from the factory. But they also have a hot air intake coming off the block. If you rip that POS off you now have a factory CAI. Whalla.
That helps the engine warm up, once up to temp it should close off and be a CAI.
My 2.8 had the same thing, it pulled from beside the radiator so it might have been a "ram air cold air intake"
Not to stir things up,but I would like to throw my two cents in if I may . I took a 3 inch hole saw and drilled through the bottom of the airbox and into wheel well plastic piece then put in a pvc 2 inch shower drain and added a 45 degree elbow pointed to the front . I have a K\N filter in there before I started
If the filters didn't work, how have they been able to sell so many? They don't have the marketing power of Microsoft...
Because, and I firmly believe this to the core of my being, 95% of Americans are F***ing stupid.
