Alternator wiring
dieselarruda
10+ Year Member
Hello
Replaced alternator on 1988 ford ranger truck 2.9L
what is the wiring order? I did not label wires for re installation
3 wires
Green with red stripe
white with black stripe
yellow with white stipe
Hello
3 wires
And the other cable with two black with orange stripe and yellow with white stipe
Hello
3 wires
Green with Red to terminal "S"
Yellow with White to terminal "A"
The info I submitted above was from my Haynes manual. I went out and looked at the connections on my 1987 Ranger 2.9 and both cables connect with a push on connector so I can't verify the color codes.
My apologies - don't want you to fry the new altenator.
Their are six wires, are they all needed for the alternator?
3 go to the main(larger) alternator plug and 3 go to the voltage regulator plug the smaller one.
https://www.facebook.com/photo.php?...95153792.25896.100002179975308&type=1&theater
i have the green with red stripe on the sta and the white with black stripe on the sta too
and the yellow with white stripe on the bat, and i have the two black with orange stripe and the other white with black to put on the alternator and need to know what wire for the fld and ground and the one by its self thats not labeled
rewiring my alternator
here is the a video http://www.youtube.com/watch?v=RzUq2pykmHs&feature=plcp
i think i wired it wrong because the green wire on the solenoid started to smoke so let me know what wires to hook it up right.
and when i put the positive and negative on the battery they throw sparks and i guess its wired wrong
what is that alt off of?
X2. That alternator is not factory. Do you have a diagram of what each post says? I would also recommend using connectors rather than wrapping the wire around the post.
how many times/places are you going to post about your alternator? put the post in the proper forum and im sure if somebody knows something they will be glad to help. no reason to cross post.
