RaceRangers Build
Right on man, hope you don't run outta talent out there. It totally blows
All mounted up, sits way further back and low compared to the 4.0 V6
More tubes to be added
That is some serious bracing you got goin on....you ever gonna build a dash in that thing?
Now I really look forward to seeing this beast in action. Do I really wanna ride in this now its got a v8 and the way you drive, you betcha.
For sure man! We are adding a lot to the cage right now then building a dash. Also making new radius arm mounts and moving the beams forward to run 35s.. Can't wait.
Radius arm mounts are way beefier than the old ones.
And what I am most excited about:
We hacked off the Camburg engine cage and are building a whole new cage going through the firewall to the cab cage.
Soo sick. That things gonna be nuts. Maybe ill see it out at huckfest next year? Badass truck tho!
Thanks man! Ya of the truck is together when huckfest rolls around again I'm sure I'll be there. Will be nice to see how the v8 pulls in the sand
No real updates.. But finally got around to cleaning the front bypasses a lil.
Off-road mag posted this pic today. Not sure if I had already posted it here.
What engine and gears did you have at that time? And how was it with paddles?
Paddles made a huge difference. In that pic the truck had a 4.0 ohv motor with auto trans and 5.88 gears.
That's a lot of gear. I'm just wondering if I'm going to have the grunt to spin em up if I ever get back out there.
I did fine out there with the 2.3.. It can be done, just gotta keep some momentum.
Got some spare/mock up 35" tires. Can't wait to see it sitting on bigger tires.
With paddles or just all terrains? I didn't have any problem with the 3.0 and grabbers in Glamis unless I stopped.
