Heys guys....Just found this site today and joined! Looks like a awesome place.
Here is whats going on. I have a 1988 Bronco 2 2.9 5 speed. Bought it about a month ago and just got it on the road. Ran good on the 150 mile trip home with no problems.
The truck is bucking really bad and acts like its choking out. It will die when I push the clutch in most times. It always starts and will idle just fine...a little on the high side but it does run smooth.
It will spudder and buck usally down low in mph under 35. After that she runs smooth. Some days it runs great and others it has these symptoms.
I have checked the obvious and did a code scan both koeo and koer. Its got full good oil, gas in the tank, coolent is good, battery is good.
The koeo test pulls codes 89 ( axod lockup, selenoid circut fail) CCO
and Exhaust Heat control.
Cyl 6
code 77 ( opperator error during dynamic responce test wide open throttle not sensed.
And I did the KOER scan this is what codes I got.
code 86 ( adaptive fuel limit reached oe 3/4 shift selenoid circut fail)
then code 11 ( system pass)
Are those tranny codes just for an Auto? Mine has a 5 speed.
Any help would be great. Thanks guys!
Cyl 6
