bronco 2 fuel problems
kguff
10+ Year Member
Hey guys I bought an 88 bronco 2 last week it started and ran great. It needed a clutch so I replaced it now I'm not getting any fuel neither one of the pumps are pumping. What could I have done?:icon_confused:
tripped the inertia switch. flip the carpet back on the passenger side and find a little square thing with 2 wires and a red button, push the red button.. try to crank it.
I have checked that. That's what I thought as well.
check your fuses, relays, and grounds to.
have you checked for power at the pumps?
fuses are good. not sure how to check a relay and have not checked power at pumps but I will
I would start with is there power at the pump... if not, follow the wires back till you find power, fix accordingly.
check ohms on your grounds wire to a good ground..
thank you for your help the high pressure pump is bad i am changing both pumps:headbang:
