- Oct 14, 2010
- Williamsport, Pa
I have an extra set of OEM blocks I can give you if/when you stop by tomorrow.
well.....whatg you do is.......chuck the bolt in an eeeeeeelectric drill with the offending end sticking out.....
turn on the trusty grinder.....hold the rapidly spinning side of the dowel against the grinding wheel until enuff metal is removed so that it fits...
9if i understand the problem correctly--proboaoboably not.....
my springs looked identical to the expo leafs i pulled out, i put them side by side, the only difference i could see looking at them, was the eye bolt was upside down on the expo one... when i stepped on the spring, however, there was a big difference in spring rate... expos were about 1.5x stiffer
here's what me did when i did the 8.8 swap. i was also working alone and couldnt move the axle around by myself.
i already had the little cart thing, my dad got it from his work. measured how high the leafs were off the ground, then got that height matched as close as possible. once i started tightening the nuts on the ubolts, it pulled the axle up and i could move the cart out of the way.
where did you source your springs from again? maybe someone put little bitch springs on your truck before...
.Sounds like you've been busy. I need to pull my dash soon...I've got the infamous cowl leak going on....Time to get to welding...
Are you 100% sure it is the cowl? I thought that's what mine was. Then I got things apart and found nothing but pristine glossy metal in there and water marks all around the access patch.
