- Aug 8, 2007
- Age
- 37
- Battle Ground WA
I do this every day I drive and when off-road, it takes less than a second to get off the brakes and on the gas with zero rollbackONE possible scenario.
Because you got stopped on a hill.
You are holding the brakes to prevent sliding down/back and you need throttle to get going up the hill. Try is sometime.
It can be done by slipping the clutch and making it hold you instead of the brakes then getting on the gas and trying to make it up. But more than half the time this seems to result in a stall.
Also remember this little thing tranfercases have called low range...
