phlowtey
- Feb 28, 2012
My background is in high-end($250,000+ systems)home theater and custom A/V so I have an annoyingly critical ear for audio. A small cab truck does not help the situation. I currently have four 3-way coaxial 6x9's with a single 12 sub in my truck. I want to add another 12 but the rear 6x9's limited the size that I could build a sub enclosure to only about 1.5 cubic feet unless I push my seat uncomfortably forward. I decided to move the rear 6x9's into the doors. I now have the room the make a single sub enclosure with 2.5 cubic feet without having to move either seat forward. Installing the speakers in the doors worked out easier than I thought it was going to. I haven't built the enclosure yet. I will post that later. Below are some pics of the door mod.
Driver's side door panel. The existing 6x9 fits in the opening for the factory 5x8 without pushing the panel out too far.
It was hard to try and measure the depth, width, etc of the speaker in relation to the panel, door, and window mechanism so I pretty much just went for it. I picked the flattest area that was closest to the bottom and rear of the door.
I made a 6x9 template with reference lines to make it easier to line up.
I used a hacksaw blade in a jigsaw to cut the panel.
I put the panel back on the door to mark where I would need to cut the metal. I wanted to preserve as much as I could so I had something more than just the plastic to screw to.
After cutting the metal. The windows in my truck are manual. What you see here is when the window is about half way down the bracket passes close to the speaker. There was not a lot of options for placement but everything went well. It may be a different story with power windows.
Even though it isn't really behind me, the speaker still fills the rear field rather nicely. Overall, I am happy with the outcome, especially considering that I now have all kinds of room for a dual-12 sub enclosure without having to fold myself in half to get in the truck. The joys of having a single cab.
