Its the 2 larger gauge wires on the round 5 pin connectors. One is pink, the other is tan/red (not 100% sure on this one, going by memory).
The other 3 smaller gauge wires:
The red with white goes to the e-shift 4wd module.
The other 2 are for the reverse lights.
Hold on, I have to go look. I know when I pulled my harness I unplugged the solenoid pack and cut the trans range sensor.
The round one is the wires that would go to the Neutral safety switch
NSS is R/LB and W/PK normally, the R/LB is from ignition switch and W/PK goes out the truck and splices back into R/LB.
they're switches - if you find the right colors, you connect those. seem pretty consistent for Ford to use red/light blue for start and white/pink from what I have seen in that era. like sno ranger said, ignore red/white, the other 2 are reverse lights.
The colors are....pink/blue black/pink red/white black/orange. Solid pink, anyone know witch ones are for back up lights? .... Thanks for all the help!
That wiring harness is from what?
I dont have my EVTM here but:
2 of the wires are noticeably larger then the other 3. Solid Pink and ????/????
Those are for the starter circuit.
The red/white is for the 4wd module.
The other 2 smaller gauge wires are for the reverse lights.
black/pink is one of the reverse lights
the others I'm having issues finding in my wiring diagrams.
pink is starting
red/white is electric shift control
You sure that the black/orange isnt purple/orange? If it is, then thats the other one for the reverse lights.
my book shows black/pink and pink/orange for reverse lights. (explorer book)
