traans swap
duder1
10+ Year Member
i will be swaping a 85 5 speed manual and pulling out a a4ld in a 88 bronco 2. any idea wich trans is the 5 speed, any probs doing the swap ? any tips will be great, by the way they are both 4by4....... thanks
You will want a trans from 88 or newer ranger/b2/explorer (m5od), make sure you get the flywheel bolts as you may have to remove the flexplate spacer as the bolts may be a different length...
SVT
wile in there. it would be a great time to get rid of the crappy 2.8 and place it in for something better
sounds to me as if he has an 85 5-speed trans into an 88 bronco II which already has the 2.9 backed by a4ld.
Just reread your post, that 85 trans should be the tk5...
SVT
